OptsyEagle
- Sep 13, 2006
- 1,356
I removed my manual starter to get at my carburetor and the spring came unwound. When re-assembling it, I simply rewound it back into the cup and put the rope part on top, etc. When it went onto the motor, the pinion gear doesn't seem to line up with my flywheel teeth like it should, when I pull the rope. It seems to me that it should go in closer to the teeth so that it doesn't strip the teeth of the pinion, but it gets assembled with a single bolt onto the motor.
Am I missing something here, perhaps in my re-assembly of the spring or something. Maybe my starter's pinion gear is shot, but it worked fine last year when I last used it.
Any help with this thing would be appreciated.
