smallblock
- Sep 5, 2009
- 57
I am rebuilding the carb on this Johnson 2hp. There is a gasket that goes over the high speed nozzle(more like a think washer). The one I recieved for this(0302984) is larger in diameter than the old cork one. If I use this gasket it will just end up floating around in the fuel bowl,it doesnt fit snug...Is there a reason for this size difference or did I just get a dud?? Do I really need this gasket, it seems kind of useless. Any thoughts on this will be appreciated...thanks.
