1973 Evinrude 65hp
I read the FAQ about adding a tell tale so I ordered the elbow and cowling outlet. Now, in trying to find a location at the top of the motor, I am having trouble finding room for it. I took two pictures of the locations that I am looking at. One is just above the exhaust cover and the other would be in the cylinder head. The cylinder head location is only as wide as my finger, so room is a problem. I won't be able to rotate the elbow in due to room. As you can see, the frost plug is located in another good location, so I can't go there. The third location could be my exhaust cover at the top, but I read that there may be trouble there(the service bulletin). I just don't seem to have much room to get this elbow in. If neither picture works, then can I put the elbow in the top of the exhaust cover and route the hose over the motor to help push the water to the top of the cylinder?
