Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Correct procedure for doing a compression test?
  • Correct procedure for doing a compression test?
    Hello, I've been givin conflicting advice. Does any one know the correct procedure for doing a compression test on a 2 cycle V4? A couple of additional questions I had are: Do you remove all the spark plugs before starting the test?
    Where do you disconnect the power pack so motor wont start?
    Where do you hook up the remote starter if working alone?
    Thanks.
    Re: Correct procedure for doing a compression test?
    Remove all spark plugs, pull the lanyard kill sw to disable ignition and check each cylinder (crank for a few seconds). Done. Some will claim the throttle must be wide open ... doesn't make a significant difference with a 2 s motor.
    Jim
    I don't respond to Private Messages PM's that are motor questions.
    For basic information on a wide range of topics, see Top Secret File
    Link: http://forums.iboats.com/showthread.php?t=299680
    OEM shop manual: outboardbooks.com or Ebay
    • #3
      http://forums.iboats.com/showthread....ht=compression
