model # J35ELCND
serial # E5657374
I belive it to be a 1973 35 hp Johnson outboard with the long shaft. The internal wiring harness is breaking down badly with much of the wiring insulation brittle. I've patched and replaced many of the wires but am concerned about it failing anyway.
What wiring harnesses will fit? Are the harnesses somewhat universal with the Johnson / Evinrudes during this era? Will a 3 or 4 cylinder harness work (obviously not using the extra wires) or must I find a 2 cylinder harness?
Would a harness from a 28 HP Johnson model no J28ESLCUC ser # E6257574 work?
Thanks in advance.
serial # E5657374
Thanks in advance.
