bang4dabuck
- May 24, 2009
- 296
I have a 1987 90HP Evinrude.
1) Is this where you would start ?
2) If so, does this wire usually end at the rectifier and if so can I test it there or is it a sealed up box not meant to be taken apart ?
3) Anything else to look at ? The key switch is pretty new (6 terminal), was advertised as a motorcycle switch but generally looks the same as my old one. I could always jump the 2 terminals to verify that it's not the culprit ... right ?
thanks
thanks
