I have a 1995 90hp evinrude, the other day when i was on my way back from fishing and the water got real shallow so i raised the motor and went through it, i saw sand kicking up. well about 10min up the water my temp horn went off, looked at the motor it was not pumping at all. i figured it was stopped up so i put it in neutral and gave it some gas, it pushed a little water at high rpms. anyways i got back home and hooked it to the hose and it was pushing out good water, so i thought it was unclogged. I then lowered the motor into a big tub to see if it would pump water without the hose pressure but it didnt. So im guessing i jacked up the impeller when i went through the shallow water.
can anyone give me some info on how to change one out?
thanks casey
thanks casey
