relocyo
- Apr 14, 2010
- 446
i just replaced the carbs on my 1978 johnson 85 hp #85ml78c but now the air housing unit that came with it, the shifter and throttle cables dont fit like they used to. but throttle works fine but the gear shifter (seperate handle on control box) wont go into forward or reverse. when i pull to shift it wants to squirrel around at motor end and wont friggin shift! its sitting with the black twister adjuster behind the anchor point on the air box. when before it was in front of the anchor point. so i dont know what to do.... any ideas guys? thanks in advance...
p.s. i cant force it forward of anchor point...
