Captain Ed in LJ
- Apr 27, 2010
- 8
I purchased a used powerhead that came from a jet boat and put it on my outboard. The guy I bought from said the idle was set (at least 1500rpm) high for the propulsion system.
I've got the powerhead running, the thottle cable is not connected, the butterflies are closed, the cam is not touching the cam follower yet the idle is very high. The idle screw has no effect on the idle. Is it possible the timing has been adjusted (for the jet boat) to create such a high idle? I don't know of anything else that would effect the idle speed.
