longhornation
- Mar 21, 2010
- 17
got the motor started today. It had been sitting for over year. I noticed when i pumped the ball on gas line that a few drops of gas was leaking out of the clear bulb on bottom side of carb. when the motor was running it was also leaking in the same place. The motor would also hiccup at low speed. I could see air bubbles at the same location of the leak. any advice?
