Re: Aqua meter tach on a V-4 Johnson
That motor doesn't have a "stator", or "poles".
The next question is just what is the tach designed to work on? My best suggestion is to set it to 4, hoping it is designed to get its pulses from the ignition system, which is what you need. There are 4 pulses per revolution available at the stud on the side of the magneto (or one of the black wires at the igniton switch--the other black wire is ground)
If the tach is designed to work on an altrenator stator, you are out of luck.
Many Aqua Meter tachs require a transmitter. Hope yours isn't one of that kind, unless you have the transmitter.
EDIT: Those 4 pulses at the magneto are two (+) pulses and two (-) pulses. Kind of underscores the need to have a compatible tach.
