Re: Evinrude 115hp jet motor - I need a replacment
you may need to get better confirmation thru a dealer,but I believe a standard outboard powerhead will replace it.BUT,you need to derermine what engine you actually have,around 95 ,was a transitional year,you had crossflow engines and looper engine.Both 4 cylinder.Do you know the differance,?if you have 4 seperate plastic carbs its a looper vs 2 alum.on xflow.You can go to the Bombardier website (BRP)and look up your year ,then compare.Boston whaler may have the info for you.Your engine can more than likely be rebuilt by an outboard rebuilder.Its not different from an outboard.IBOATS also has rebuilders,look under engines for rebuilt prices
