I am trying to find the correct spark plug gap for my 1978 Johnson 35 HP Engine.
One dealer's marine mechanic said to gap it at 0.30" but the manual said to gap the plugs at 0.40".
I am running the motor at slow speeds for long periods of time and want to keep the spark plugs clean and unfouled.
Should I gap the plugs to make the engine run hotter at slow speeds.
I am currently fishing "Idle speed only IDNR F&W lakes in Southern IN making it impossible to open it up and clean out the carbon. They give tickets if you go too fast on these small strip pit lakes.
I am going slow to use a humminbird 898c SI sonar also. Can't go over 4 to 6 mph or the SI won't work right.
