Re: 1980's 115 Evinrude runs perfect off hose but not in the water
the carbs are clean as a whistle i checked that screw on the bottom of each one and really clean. It has good gas when in gear it moves and wants to start to plain out but then boggs down again, im gonna do a compression test. One of my friends said it could be one of the coil packs so i need to check for spark on all four cylinders all the plugs look a little wet but for a 2 stroke isn't that fairly normal? i need to replace them all anyway. How much do the coil packs for these things usually run?
Order carb kits, remove and dismantle carbs, remove jets, clean orifices with wire and spray cleaner, soak them if they're gunked up, reassemble with new parts and seals.
Check coils for cracks, use the spark gap tester pictured in Tash's post, get them at any auto store for cheap. Set gap to 716th inch, it should give a bright blue spark, all plugs out.
Get the service manual. Save yourself a lot of money and grief.
www.outboardbooks.com
