Happyfingers
- Apr 12, 2010
- 29
Giday all
I have just finished installing a new impeller kit
this one
and i put the motor in a tank and it seems to be working though im still unsure if i did it correctly
water after 30 secs or so comes out of the little hole just below the engine, its not a real strong stream but it doesnt get hot, if i idle the engine for a long time the water flow seems to stop
when i installed the pump kit i didnt seal the gasket with anything (the metal plate) and im concerned that this is wrong
when i put the ears on the water intake before reconnecting the stem to the engine (just to see what would happen) the water seemed to squirt out from underneath the plate as if the seal wasnt all that good
are you supposed to seal the metal plate of the impeller housing with something ?
there also seems to be water coming out of the area where the engine pivots on the plate that mounts to the tinny, is this normal ?
if ive done it wrong i can just pull the engine apart again and do it correctly thats no problem it was reasonably easy to do
i was gonna get the engine serviced even though it seems to run quite well
but after the shop told me it was $279 for a service for a 15hp outboard i nearly choked
the engine prolly isnt even worth that much
any help is much appreciated
the engine is pretty much the same as the one in the picture
this one
