Soggydog23
- Mar 27, 2010
- 15
I have had this motor for ten plus years and never had a problem. Every winter pull the carbs and clean and do regular maintenance on motor.
Last week put everything back together and ran it on muffs in driveway and it ran like normal (revved to 5500 RPM + and idled fine. I get it out on the water today, it starts right up, but will not run unless you choke it. I' m not sure if I messed something up or not. Any suggestions? Thanks for any info.
