Re: 9.9 hp Johnson tilt pin
Where can I order one of the pins that retains the motor in place when
I tilt it down in run position? I am not sure what this pin is called.
The pin with a plastic clip on the end that goes through one of the pairs of holes in the stern brackets to adjust the angle and hold the motor down when going astern?
"Tilt pin assembly" Possibly part no 390441 or 432452.
Go to
http://shop.evinrude.com/ then the electronic parts catalog , find you engine by make, year, hp and model number and the look at the "Midsection" diagram
Any dealer should be able to get it for you.
OR
do as I have done, get a bit of stainless steel round bar the same diameter, put a thread on each end and put it permanently in position with a couple of nuts on the ends
