coastaloutdoorsman
- Apr 7, 2010
- 2
HELP!!! i bought a 1976 Johnson 35 and was told it was fine. It runs great on land and no more than 2300 rpms in water. I'm getting fire to both cylinders, my plugs are new and gapped properly. I believe my compression is good. Only the bottom cylinder will run. Sometimes the top cylinder will sputter a little. Also, its using large amounts of fuel, which seems to be spilling out of the choke. The previous owner told me the head gasket was recently replaced. Any suggestions? im not rich, nor am i an expert at outboard repair! This shoud be either a clogged carb or stuck float affecting fuel to the cylinder or a head gasket, right? I greatly appreciate any advice!
