What is the proper idle speed...motor runs very good but will not idle in neutral position.
L ledodgen Recruit Joined Apr 7, 2010 Messages 1 Apr 7, 2010 #1 What is the proper idle speed...motor runs very good but will not idle in neutral position.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Apr 7, 2010 #2 Re: 1991 60hp Johnson Outboard Motor 600-750. if link n sinc are properly adjusted. you have to set idle speed in the water, and in gear, it will idle faster in neutral. you could have dirty low speed jets, or pickup tubes.
