How does the 8 carbs feed each of the 8 cylinders? Back a few years ago, the lowest carb on the port side was leaking from the vent so I took it apart, figuring a needle and seat, changed it and the problem was solved. I am a bit concerned because the sparkplug lowest cylinder on the starboard side runs cleaner than all the others. Does the lowest carb feed the lowest cylinder? I have a thought that the retaining spring for the needle and seat may have been installed wrong and may be holding the float up and restricting the amount of fuel it gets or is that even possible?
Thanks
Thanks
