I have a 1964 model 9.5 that has the male end of the fuel connector pressed into the body of the handle, actually on the side and back some. The fuel line hose connector will not seat completely and lets air into the fuel line causing rough running. If I hold the fuel line down with my finger it's runs alright. I ran the fuel line from the tank straight to the carb and the motor ran fine.
How do I go about removing the old male connector and replacing with a new one? If it is really a hard job I'll just by bypass the connector and run a straight line from the fuel line to the carb and by pass the male connector.
