Hi everyone I am trying to restore and old Johnson Super Sea Horse a RSD21 I think is a 1959, my main problem refers to water in the bottom cylinder I already change the head gasket 2 times , with no luck, the compression test is around 100 PSI each cylinder. When I run the motor in the tank it runs ok a little rough but ok, the water in the tank after 10 minutes working is all oily, I have been reading a lot about this problem but I still cant find the solution, I don?t want pull out again the head , if I am not totally sure.
The water in the spark plug looks milky
. I have a great blue spark in both cylinders.
I read in one post about the exhaust system could it be?
Thanks in advance for your comments.
