bob johnson
- Feb 25, 2009
- 4,304
1995 115 johnson looper.
motor seems to be running very good...
runs all the way to 5800 rpm no problem..
after the motor warms up...it appears one head is running up to 180-190 degrees at low rpm.
water pressure at idle is about 8-10
at wot the water pressure is 30 psi!
at wot the temperature will fall back to about 140-150
so It gets kinda warm...putzing around at low rpm
I have two temp sendors and one gauge...I have a switch to go back and forth from reading one head orthe other..
I think the guage is actin gup...because when ever I get high readings, on one head I get no reading on the other..
dont know if its the switch or the sender..
but the temps can easily be seen falling at I cruise about 4000 rpm!!!
if in fact one head is getting hotter than the other..
what can I do, to fix it, so it doesnt run hot at low rpm??
is the head water passages clogged maybe??
will I be able to fix it with the head off??
mechanic tells me its a real pain to reinstall the head with these big o-rings and no gaskets...
he says if the head warped I may never get a seal..
I am getting a little leakage into the cyliner on the non hot side
thanks
bob
thanks
bob
