Replaced the waterpump on our 1979 115 hp Johnson, 115TL79R. The trans is not shifting. Haven't fired it up yet. Been trying to turn the prop by hand, its turning over the crank in f, r, and neut. no difference, prop won't freewheel in neut. Can't really see the shift rod end,( couldn't see it before I removed gear case either, what with the carbs being in the way and all ), but reinstalled shift rod bolt and it tightened up. Thanks in advance. Brian
