I am going to attempt a water pump change on my '81 25hp Johnson. I've got an original repair manual to help me through it. With the shift linkage, do I just take out the bolt shown in the pic? Does it matter what gear the motor is in when removing the bolt/nut? Reverse seems to give me better access to it. Does the bolt come completely out or do I just loosen it up?
Also, the water pump replacement kit gave me a small package of grease. I know they say to grease the driveshaft spline. Are there any other areas that should get grease? And if so, what type of grease? Any other tips or info that might be helpful?? Thank you!
