what is the fuel mixture on a 1980 70hp johnson vro
T thepikeman Cadet Joined Sep 1, 2009 Messages 11 Apr 2, 2010 #1 what is the fuel mixture on a 1980 70hp johnson vro
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Apr 2, 2010 #2 Re: 1980 70hp johnson vro fuel mixture well unless you have something very much out of the ordinary. your motor is not a VRO motor, it has the old standard premix fuel pump. which fuel oil ratio is 87 octane 50:1 TW-C3 outboard motor oil.
SparkieBoat Captain Joined Aug 17, 2009 Messages 3,643 Apr 2, 2010 #3 Re: 1980 70hp johnson vro fuel mixture probably a newer cowl with VRO lettering.
