I'm trying to troubleshoot my trim/tilt system after it partially failed due to hitting a floating log. When it happened, I was able to trim the motor up, but not down. Loosening the pressure relief valve allowed me to lower the motor fully, after which I could trim it up (with some noise) and down - it also appeared that I had leaked some hydraulic fluid into the water. At the boat ramp, after a few up/down cycles, the unit was barely able to get my motor to the stow position.
Before taking it to the shop, I wanted to make sure that air in the system wasn't my only problem. So, I followed the general procedure as I had found here and elsewhere:
1. With the motor up & trailering arm in the stow position, I opened the pressure relief valve slowly. At about 1/2 turn, the motor lowered into the locked position on the trailering arm, so I know that the system pressure was released. I opened the valve another full turn.
2. As a check to see if I had bent anything, I tried to physically tilt the motor up to release the trailering arm - it would only move a few inches, not enough to give me clearance to stow the trailering arm & lower the motor.
3. I removed the fluid reservoir cap - a small amount of fluid leaked out (boat was horizontal). In case the system was still full, I closed the reservoir.
4. With the pressure relief valve still open, I cycled the trim switch "up" for 30 sec (sounded normal) and then "down" for 30 sec (sounded frothy). and repeated for several more cycles to purge any air in the system.
5. I opened the reservoir cap to see if the system would take some ATM fluid, and a lot of fluid overflowed. I quickly closed the reservoir.
6. I closed the pressure relief valve (to my best guess of 40-50 in-lbs), and tried to trim the motor up/down - no movement. (The dual trim pistons were fully extended throughout this cycle and also did not move).
7. I reopened the pressure relief valve 2 turns and tried again to purge any air from the system with 30 sec up/down trim cycles for several minutes (ending on an "up" trim cycle), then opened the reservoir and more fluid overflowed.
After repeating this purging process several more times, it appears that both the up and down pump direction cause fluid to be pumped up into the reservoir, not out of it, and I was never able to get any ATM fluid into the system. On the chance that a stuck check valve could cause that to happen, I tried rapping the valve body & trim cylinders with a plastic mallet - no change.
I'm sure my system is low on fluid, but I haven't seen anything about problems filling the reservoir, so, I'm stuck. Has anyone had a problem like this? Thanks for any assistance.
