1987 erude 88 spl
I was out fishing yesterday,motor ran great all day untill the way back to the boat ramp.was heading back to the ramp after a day of fishing and out of nowhere the motor just fell on it's face and died.started it back up and went to take off and it would barely go.
Tried pumping the bulb,with nothing changing.Also tried pushing in the choke,when i would push the choke it would change a little but not enough to matter.
The motor would rev up with the high idle but when i would put it in gear to go then i get nothing?The motor would also die if i left it idle for more than 5 seconds or so.would not run hardly at all without using the high idle.
I figure it is a fuel problem of some kind but wanted to get some advise from the pros here before i started tearing er down.
Thanks,
Shane
Thanks,
Shane
