tmcallister
- Apr 29, 2009
- 6
I have a 1986 Johnson 110 HP outboard with minor issues. The engine will run great if you pump up the fuel line... start... and drive to your destination. However after about an hour drift fishing... I try and start the motor.. it will start up fine.. take off to get on plane.. and then it falls down and dies. I go pump up the fuel line.. then usually starts up perfectly and goes down lake with any issues. It seems like the line can't maintain fuel pressure.. and I am wondering maybe if she needs a new fuel pump.. or bulb.. whatever it takes..
