Starting
FAT RAT
I Have A 1997 50 Hp Johnson Model J50tleds.i Have Trouble Starting Engine But Once It Gets Warm It Will Start Immediately. If I Push Choke Just Once Seems Like It Floods Easily. I Put New Set Of Plugs In Ql78yc With A Gap Of 30 Didnt Seem To Help Starting Issue. Any Help Would Be Greatly Appreciated.
diver_down
Re: Starting
check spark with gap tester, you might have a weak spark, test compression, replace plugs (put in correct ones) and clean carbs. unless you have an intermittent spark issue this should fix it.
