Re: 1996 Johnson 225 hard start
Ok, so what you did is this:
Your first steps were to fill the fuel system up with gas, from the tank to the carb bowls, by pumping the primer bulb. At the point when the fuel system is full, the primer bulb will get firm and remain firm.
The next step, you opened the red elec. primer lever to manual position. This basically opened the valve that lets fuel flow up to the back side of the manifold, bypassing the carbs completely, and allows (when you pump the primer bulb again) the fuel to squirt directly into the manifold, enriching the fuel charge very much.
Close the manual red valve, hit the key and it starts.
So, what is happening? First, when you press the key in, the solenoid is supposed to open the valve on top of the primer solenoid , and allow that gas flow to occur via the electrical method, instead of having to manually open the valve with the red lever. At this point, I would pull the primer hoses off the back of the intake one at a time, and absolutely verify that I had gas flowing when the key is pressed in, manual red lever is in RUN position, and the primer bulb is squeezed. The engine does not need to be running, or even trying to start it. Just press key in when in ON position, and then pump primer bulb. Check for gas flow.
If NO gas, then the valve on top of the primer solenoid is not functioning. You already know that the lines are open, because you get fine gas flow when in manual mode. YOu just gotta make sure the gas flows when you press the key in.
I once had a primer solenoid that was ON so much, from the user pressing the key in, that it got so hot that the body of the solenoid melted the glue holding the windings into the case, and the windings sort of slid out of the bottom of the case about 1/2". Simply by weight of gravity, as your primer solenoid is oriented vertically. It would no longer work electrically, still clicked, but the shaft inside that moves, and operates the valve was now out of position by 1/2". But it would work fine manually.
Check it out and post back, please.
