I have a 1989 120 hp johnson. the only way i can keep it running is to hold the choke in or force fuel to the fuel pump by squeezing the bubble. i have put on a new power pack, new stater, replaced the metal tank with plastic, replaced all fuel lines, had carbs cleaned twice, new fuel filter, disabled the automatic oiler and started premixing, new key switch, have a compression of 127 on all cylinders, has very good fire. i have had trouble out of this motor since spring of 2009. have narrowed it down to the vro2. any suggestions? i am about to give up!
