Could someone answer a couple questions for me please? First, im replacing a melted rectifier/regulator and the superceeded replacement i got only has 3 wires that go to the terminal block yellow,yellow/gray, and gray. My old one had a fourth wire blue. Should i be alarmed that the new one does not have this blue wire? 2nd, is there a torque setting for the stator ring? 3rd, what is the flywheel nut torque setting i have found on here 150-155ftlbs but that was for a 1989 im thinking it must be the same. Any help would be greatly appreciated. Thanks.
