I just bought a boat with an Evinrude 115 outboard on it I think?!?! Model on the bracket is 115999R S/N J0002087 The block has numbers on it also the middle of the motor behind the flywheel is 396 244 (bigger letters) 1 IK23 Then on the left side clinder near freeze plug is FL2784 the cylinder and the block or intake are stamped 9604. Any info on this motor would be helpful. known facts : It is a 4 Cylinder non VRO, the cover says its a evinrude 115 the Mounting bracket is from a 1978 135 HP (I really hope this is right)
