What is fuel to oil mixture for 1994 140HP Johnson outboard motor? Thanks Musicman2
M Musicman2 Recruit Joined Feb 19, 2010 Messages 1 Feb 19, 2010 #1 What is fuel to oil mixture for 1994 140HP Johnson outboard motor? Thanks Musicman2
1946Zephyr Vice Admiral Joined Oct 21, 2008 Messages 5,556 Feb 19, 2010 #2 Re: fuel/oil mixture for Johnson outboard 50:1
E EN2 Chief Petty Officer Joined Nov 19, 2007 Messages 404 Feb 19, 2010 #3 Re: fuel/oil mixture for Johnson outboard 50-1 16oz TCW3 for 6gals.
kenmyfam Supreme Mariner Joined Aug 10, 2006 Messages 14,385 Feb 19, 2010 #4 Re: fuel/oil mixture for Johnson outboard Musicman2 said: What is fuel to oil mixture for 1994 140HP Johnson outboard motor? Thanks Musicman2 Click to expand... Hello and welcome to iboats. Does your motor have an OMS (oil metering system) if so there is no need to mix oil with your fuel unless you are unsure the OMS is working and mixing as well while you check the oil tank level movement.
