I have a 9.9 Evinrude 1982 model E10RCNS.
The steering bracket has been damaged (part no: 0325166) and the left bush has been fractured with two small pieces coming away - allowing the tilt bolt and clamp assembly to swing away on the left.
Is it possible to weld this area or I am dreaming? I know very little about engine mechanics or welding - but I would obviously prefer this option over replacing the whole bracket - as i suspect this would not be easy? Even more of a pipe dream - could I use something like JBWeld! If I do need to replace the whole bracket (if I can get a new bracket) - is the replacement going to be hard - maybe too complex for a newbie like me. Are there any descriptions of such a process anywhere on these forums (I have had a search but not found anything yet.)
I can upload an image if necessary.
Any help or advice appreciated.
