DargelJohn
- Feb 14, 2010
- 337
I am rigging a 1996 88 SPL and I am having an issue with the control cables.
The range of motion is too great on the shift cable. The gears are binding in forward and reverse. If I move the shift arm manually, the gears feel fine. When I connect the cable and use the binnacle, it pushes the arm too far in either direction. These are older controls that were used with a 1995 Evinrude. Thanks
