When I lifted up on the red 'button' that releases the control lever to be pushed forward or pulled back for reverse, I felt a snap and the control lever could not be put in 'forward' or 'reverse'. I was able to take a pair of pliers and lift up enough on what was still attached to the end of the cable to put the motor in both reverse and forward to get the boat back on the trailer. Is this 'button' assembly something that can be replaced or will I need a complete new lever assembly?
