hello all, i have a 66 9662a evinrude with a shifting problem. its real hard to shift between f n r. sometimes you have to play with the throttle to get it to go. i have done some searching and everything i have found has been related to cable controlled units. my shifter is on the engine. i checked the lower end oil and found no water at all along with clean oil. i plan on doing an impeller here shortly and would like to take care of this problem while im in there. any advise is greatly appreciated.
also, i have noticed last two trips out , that when sitting at a high idle waiting for the trailer, that when i throttle up it runs like it has no power at all for about a min and then all returns to normal. normally this would have made me think fuel starvation/ clogged jets, but it only does it when its idled for a few mins. im thinking maybe its loading up with oil in this time. it smokes like crazy when i does its little tantrum and then all goes back to normal. i was thinking about cleaning the carbs while i had everything else apart. i do run a good fuel filter in the line between the tank and motor.
