Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Carburetor Problems for 1990 Johnson 60 hp
  • Carburetor Problems for 1990 Johnson 60 hp
    I have a 1990 Johnson 60 hp outboard motor that will not stay running. I've had $1,600 boat repair to it. Rebuilt 3 carburetors, replaced stater. After carburetor "rebuilding" motor still not running correctly. It runs for about 15 minutes at 3500 rpms then just dies quickly. After about 5 minutes, it will restart and runs only about another 5 minutes then dies again. Still have problems cranking motor when it's cold, no matter how much I choke or don't choke it.
    Repair shop had problems setting carburetors on motor; brought back to shop 5 times. They finally took the boat back to the lake and found carburetor adjusting screws were off. Ran fine for 3 outings but still have a hard time cranking the motor when cold.
    Motor has good compression, new spark plugs and new fuel. Mixing oil on my own; looks good. Does the motor have an oil shut off sensor if the mix is bad?
    Mixing oil and gas 2 to 1. 16 oz oil to 5 gallons of fuel.
    Baffled why we can't figure out what's wrong. Do I need new carburetors???
    Seems it's either electrical or carburetor.
    HELP PLEASE!
    Re: Carburetor Problems for 1990 Johnson 60 hp
    Check your spark for starters when it dies. Sounds like something electrical.
    sigpicSignature- If you have fuel and spark- Have you checked compression?
    • #3
      sounds electical agree. coils, power pack heating up and failing.
      FLORIDA GATORS
      TEBOW Country
      Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
      That is what these forums are for. Post your questions, in the appropriate Forum.
      • #4
        kill switch? bad connection?
        -1964 20Ft Riviera Cruiser, 1961 14.5Ft Critchfield, 1962 15ft Orlando Clipper
        -1959/60 10 Hp Evinrude, 1961 Mercury 500, 1958 35 Hp Johnson (Sold), 1990 25 Hp Johnson (Sold), 1985 60 Hp Johnson
        1962 Orlando Clipper 15FT http://forums.iboats.com/showthread....hlight=orlando
        http://photobucket.com/sgdteam
        • #5
          I'd start with the basics. The only adjustment on each of the 3 carbs is the low speed mix screw. That will have nothing to do with running and stalling at 3500 rpm.
          Back to the basics. #1- What spark plugs do you have?
          • #6
            Also, what exactly is your starting procedure, step by step?
            You might not be aware that engine overheating can cause your stalling symptoms. Besides failing thermostat, the engines were subject to problems related to the tell-tale or overboard indicator as detailed in SB 2276. Please click the thumbnail.
            • #7
              It runs for 15 minutes, if it were overheating wouldn't it shutdown after a couple of minutes compared to 15?
              • #8
                Possibly, but the problems related to the service bulletin were caused by air entering the cooling circuit. This was more related to operation and setup than to time.
                This was of sufficient concern that Rapair (Now CDI Electronics) also published it in their electronics troubleshooting guide.
