Cam follower roller
surrender
the roller on the throttle cam (part number 0432572, 1996 Johnson 88) is gone, broke off. Can I just get a sleeve and slide it on the shaft to accomplish the same thing? the part is $12 when i can get a sleeve for pennies. Is it not round?
ezeke
Re: Cam follower roller
I believe you want Roller and Sleeve Part # 0432639 - list price is 6.49 US.
Be sure you have the ring to hold it in place - part # 0324678.
Vic.S
part number 0432572 is a cam follower and fits a variety of models but not it would appear a '96 88
Correct part numbers as per Ezeke's post
Fair enough if you have the facilities to make something but to save even $12 ???? how much is your boat and motor worth ???
Bob Gilvary
All the ones I've ever seen, were held in place with a tiny o-ring. Thiat is on the OMC engines.
surrender
you guys are right. i was looking at the wrong number. No problem
tashasdaddy
replace it, not having it throws the link and sinc off. very common problem.
14ftgrumman
After you replace it with the correct parts, make sure to do a link & sync. as td mentioned.
This roller, along with opening the throttle, is the component that ensures correct engine-ignition timing.
Culpy14
If anyone else finds this, I have gotten by with using electrical tape when my outer shell of the roller broke. Haven’t had issues while waiting for parts to show up.
909
You depend on this outboard to get you and your family home safe.
Try to find elsewhere in your life to budget $6
