Over the last two seasons tilt has slowly failed when using the button on throttle or OB. 1st very slow raising then need assistance by pulling up on motor while somone else held button. Tried bleeding air in reservoir numerous times. It is now to the point it wont budge at all unless lifted by hand by releasing the bypass. Could I need to replace the drive motor or is there something else I should look at first?
