dhardin78737
- Aug 21, 2004
- 19
I recently bought a 18.5' Javelin with 130 hp Johnson (1995). It has oil pump and separate oil tank. I accidently added oil into the gas at 50:1 so basically I have twice the oil I need...probably about 10 gallons of gas in tank.
Any ideas what I need to do?
Can I just run this tank of gas out and then refill with just gas?
Should I try to unhook oil pump?
Do I need to drain the gas tank? If so, how?
Would appreciate any advice you could give.
Thanks
Thanks
