I have a 1972 johnson 20 H.P. Outboard. It has a problem starting. When i try and pull start the motor it does not do anything. But when I add gas into the carb, it fires up for a couple of seconds and dies. I just rebuilt the carb and replaced the points and condensers. Both cylinders have good spark, the fuel lines are all clear, new gas, fuel does pump through the fuel pump. Just dont know what else it could be Any help is appreciated.
