I have a 1989 Evinrude and when I turn on the switch I get the initial short beep which is ok but many times it is a continuous chirping. This is with not turning over the motor and stone cold. Is this a short or could it possible be a bad horn.
if horn is in the controls..it is easier to disconnect tan wires at engine and disconnect low oil wire..should result in the same result..I think.
