Boat Junkie
- Dec 21, 2009
- 7
Hello everyone, I purchased a 25hp evinrude from a guy, he said the top cylinder has 85 psi and the bottom had 120psi compression. I removed the head and the piston head looks good and cylinder walls were smooth, have not been able to look at the rings, the head has carbon build up. Do you think it may be burnt rings? Can I polish the head?
