The gas tank and fuel line assembly for my 1965 Johnson 9.5 HP outboard is giving me trouble. It is sucking air....sometimes at the worst time. So far I haven't been stranded anywhere, but I want to eliminate the possibility. The tank and fuel line are different ages (kind of mismatched and old).
Therefore, I bought a new tank plus a 10 ft primber bulb and fuel line assembly. The six gal tank needs to be in the front of my Carsten Bluebill (duck boat). The primer bulb as it is now attached will often be underneath many decoys and other gear....near the front of the boat.
My 1st question is.......Can I turn the assembly line around after taking off, reversing and re-attaching the primer bulb? This would place the primer bulb back by the motor and make it much easy to use. The 2nd question is....Will having the bulb farther from the gas tank create any issues?
Thanks in advance for your help, Jim B.
