Tacklewasher
- Sep 18, 2002
- 1,588
Seems I keep having issues with the colder weather.
Anyway, in starting my 1980 115hp Evin, I'm having a bit of trouble. I pump the fuel fine and get the motor started okay, but it ends up dying and I have to re-pump the bulb a fair bit. It seems like I've run out of the fuel in the float bowl and nothing has been drawn from the tank. This happens a couple of times while warming the motor up and getting everything in it's place. Once I get going, the motor runs fine.
After fishing for a 3 hours or so, it starts up fine again.
It's a bit hard to troubleshoot in the driveway as I've turned the water off.
Is this a sign the fuel pump is going or might there be another issue?
