Re: 1978 Evinrude 4hp water tell tale hole
Of course in the Seagull all the flow of water is output from the hole in the cylinder head; this is part of its wonderful simplicity.
In the Johnson, to be sure not to subtract water to the engine cooling, I made the hole at the very end of the jacket path, just before the input to the exhaust. Moreover, the telltale hole being very small, the whole circuit remains under pressure and no air lock is feared.
I never noticed overheating and a glimpse from time to time assures me that water is running regularly.
One problem with an outboard fitted on the transom could be the peeing inside the boat while reversing, but in my Drascombe Dabber the outboard is fitted in a well draining to the sea, so this does not happen.
All the best,
Sandro
P.S. An English language question:
I could not find an apter word than "peeing". I saw it used also in this forum. Is this a vulgar term? If so I apologise and please warn me and I shall not use it anymore.
