I recently bought a 1988 200XP. After replacing the water pump, I noticed that one of the tell lines on the water return is broken off, and I cannot figure out where it should be attached. I have attached a photo. It is the line with the white arrow pointing to it. It is on the starboard side, coming off the tee just before the pee hole. It is looped upward in the photo.
Looks like it should run under the carbs, but I can't find any connection. If anyone can look at the pic and help me out, it would really save me some time.
Thanks!!
Thanks!!
